Aiwa XC-35M 5-Disc CD Changer Logo
Joan Bradfield Posted on May 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need cd fixed as not playing
Great old player but cds not playing. go through all the motions but does not seem to be reading it. Have cleaned actual stereo and also cds but still only whirring sound. Cant find where to get in fixed in Dublin so perhaps you can help me. pretty old PX-E850H. E mail. [email protected]
sonic boom electronics
Level 3:
  • Master 1,557 Answers
  • Posted on May 08, 2012
Master
Level 3:
Answers
1557
Questions
Helped
386557
Points
5474
If the head has been cleaned properly and it wont read then its either blown its laser or the laser needs turning up
1helpful
My emerson hd8197 compact disc player won't stop skipping
Hello Keira
Buy a CD Lens Cleaning Disc from Walmart. Run that a couple of times. If that doesn't fix it send it back.
Oh, it a portable Sony Disc Player clone. That means it has to be 15 years old or more. Actually, I found the date '18/6/2007'. It's a new 14 year old device that has been in storage. Emerson are a bargain basement brand and generally lack quality..
https://www.ebay.com/itm/Emerson-60-second-anti-skip-HD8197-compact-disc-player-w-headphones-Adapter-/392716405989
some generic fixes
https://www.google.com/search?q=emerson+hd8197+compact+disc+player+won%27t+stop+skipping
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
My cd part of aiwacd3 wont play any longer. i looked through the top window and it appears that the disk does not fit centrally under the playing head sometim and then the head spins a few revolutions,...
hi there.
Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Step 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Step 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Step 3 Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
if you need more info go to this link.
cd won play Google Search
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
My music system will mot play CDs
Hi, Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Instructions
Things You'll Need:
* Glass/lens cleaner
* CD cleaning disk
* Dry duster
Tips & Warnings
If the CD player does not turn on or off, or the power indicator flashes infrequently, the problem is with the power cord or the circuit board, in which case the CD player will not be able to be repaired.
If the CD player still does not work after these steps, the lens has probably been scratched, and the CD player will need to be replaced.
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
2answers
I have a problem with my CD player
hi no1angel4u, there seem to be a dirty lens issue.try clean it with a lens cleaner cd its not much of a hassle.have a nice time.n hope your prob gets solved nice n quick.
raj..
2helpful
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
2answers
Cd player not playing some cds: denon cd player ucd-77
try cleaning your not working cd with soap and water, and dry it with paper towel. tnx
6answers
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mohammad Abumuailek
Mohammad Abumuailek
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
