The left diagnostic LED stays on green.I pushed little button to left, nothing happens. Is the Mother board shot? I need to recover photos and songs . how can I get the hard drive out, or get data if I can't start it up? no s.up chime or anything . thanks
This is a problem that manifests itself on some of these models and also on some of the G4 models before it.I have a G4 here that does it and last week I was working on a machine like yours doing it.
The thing is, just be a little patient. Press the power button and hold it, count to 10. it may come on. It may not. Try again and again until suddenly you hear the fan start up, a moment later the **** happens and the mac starts up normally.If you are trying to do it with the back off, just short the 2 copper coloured prongs that line up with the power button with a flat-blade screwdriver. (That's all the button does.)
If the worse comes to the worse and you cannot get it to start, don't worry, your pictures are safe on the HD and as you've got the back off, I think it's only 3 screws to remove the HD. Yopu can then connect it to another mac to get at the pictures.
SOURCE: My mother has a Apple
hmm may be a problem with it or the energy saving function is set, click the apple top left and go to system settings, if its not there, check on the task bar (gears picture) or in finder and it basically has the same standby settings as a windows pc
My main question is since I took the back off as suggested, the left green ,of the 4 diodes lights up, meaning the power supply works, according to an earlier answer to another question . What else, (besides a motherboard) could be wrong? and where could I get one since Apple doesn't make them any more. Is it worth replacing it? Thank you very much for any help you can give me.
Also when I push the startup button, nothing happens, no chime or any thing. But the green LED on the left does light up.
