Printer error has occurred. Turned power off and back on but problem still persists. Can not find a problem solving solution in manual.
Hi there, 2. Press
Resume button 2 seconds then press the power button until the
green light on (when pressing the power button, Resume button). 8. Press the power button again then the printer
will flash. Check
your printer again now it's ready. Regards
Well it seems like the waste ink pad error. You can override it but it will need changing or the printer will leak ink from the pad eventually.It needs a service now and the waste ink pad changing but you can reset it yourself by following some simple steps -
1. Plug in the power cord of printer.
3. Then release the resume button, but do not
release the power button.
4. While the power button is still pressed,
press the Resume button 5 times. Led will light turns green orange with the
last glow orange.
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow
green.
7. And the computer will detect new hardware,
just ignore
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
SOURCE: Message error 6A80
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: Canon Printer MX328 displaying message "Printer
Please reset the printer
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
1. Press and Hold the
STOP/RESET button and wait until it self restart.
2. Release the
STOP/RESET button the the printer is restarting.
3. Wait for a few
seconds
SOURCE: Error Number 5200 Printer Error
How Reset Canon PIXMA error 5200: The printer is turned off and plugged the power cord. Press the button STOP / RESET and hold, then press and hold the POWER button. POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Release both buttons simultaneously. Press the power button, then the printer will off Press the power button again, then the printer will be lit and ready for use.
If this does not solve the problem, here is another method:
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working.
1. Turn Off
printer, cable power still plug in.
2. Press
Stop/Reset button, don't release the button.
3. Press Power
button by holding without release and than release Stop/Reset Button.
4. Press
Stop/Reset button two times (2x) now release the Power Button.
5. Wait until
service mode to zero (0).
6. Turn off
the Printer, cable power still plug in.
7. Press
Stop/Reset button, don't release it.
8. Press Power
button don't release & than release Stop/Release button.
9. Press
Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off
printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
