We have Brew Rite Cleaner... Can we use it on a Bunn Coffee Maker?
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: Bunn Coffee maker leaking out
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
SOURCE: Bunn Automatic Coffee Maker
make sure that the machine is turned on on the left side in the back. this machine needs an hour or so to warm up the reservoir of water built in to the machine. try again. this machine should stay on all the time.
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Make sure you are using BUNN brand cupcake filters, not the shorter-sided generic variety. Also, inquire with BUNN about an optional attachment for some models that will slow down the rate of water flow. Lastly, ensure that you are not over-filling the basket with grinds. There is an upper limit to how much a coffeemaker will hold, and some people try to compensate for weak coffee by adding too much.
SOURCE: BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
