Question about Russell Hobbs RHOK3123 Cordless Electric Kettle
Leaking jug leaking water from the bottom
    Genius:
  • 1,691 Answers
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
Posted on Jun 26, 2012
    New Friend:
    Problem Solver:
  • 8 Answers
Descaled my kettle with vinegar and it began to leak immediately. The water dripped from the join between the brushed steel and plastic about where the swith is located. I'm sure that scale behaves exactly like ice does in rocks. As the scale builds up joints are gradually expanded so that when descaled the kettle begins to leak. I applied LS-X along the joint line (outside the kettle) over the leaking point and a few inches on either side. Left it all to dry overnight. Two months in and the kettle remains sound.
Posted on Sep 13, 2012
SOURCE:
When i put water in my water jug it leaks out from sumwea n the truck is running hot What could that be
The only other option is , check to see if water pump is bad. you will see a leak from bottom of water pump if it is bad. If water pump is good. Replace the thermostat. Good-Day! And make sure recovery tank is not leaking! or the coolant system is not plugged somewhere.
Oct 29, 2014 | Cars & Trucks
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
Why Kenmore refrigerator 7215 is leaking?
the condensing drawer is over flowing likely to much ice building up inside an defrosting . put some gallon jugs of water til the balance is ok between power and amount of ice present i use some 3 or 5 jugs of water.
orrrrr
you water hose is leaking . git a light an looksee
Aug 03, 2014 | Kenmore Refrigerators
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
My s 430 has smoke coming from under hood after driving but not all the time temp gauage reads normal. I had oil and trans leaks sealed but it is still happening, what else could it be? Thanks
SMOKE UNDER HOOD COULD BE COOLANT LEAK FROM RADIATOR ITSELF OR CHECK FOR LEAKING TOP RADIATOR HOSE AND CHECK FOR LEAKING BOTTOM RADIATOR HOSE.LOOK UNDER THE HOOD IF COOLANT BOILING OUT COOLANT OVERFLOW JUG ENGINE OVERHEATING FROM BAD THERMOSTAT OR BAD WATER PUMP.CHECK FOR COOLANT LEAK AT WATER PUMP WEEP HOLE.IF SO WATER PUMP NEED REPLACING.ADD MORE COOLANT UNTIL LEVEL CORRECT.TRY LOCATE LEAK. IF CAR OVERHEATED AND BOILED IT OUT. SMOKE UNDER THE HOOD CAN ALSO BE CAUSED BY LEAKING VALVE COVERS WHICH CAN BE FIRE HAZARD IF OIL LEAKS ON HOT EXHAUST MANIFOLD.
Mar 21, 2011 | 2002 Mercedes-Benz S-Class
Radiator want stay full of water or antifreeze has plastic jug on fender weld
Is there a leak somewhere? There should be green or pink fluid on the ground if there is. The plastic jug is often called the overflow this has level marks on the side of it for when the vehicle is hot and cold, cold is at the bottom end of the jug. The purpose of these marks is so you can see the levels without having to open the radiator. When the engine is cold open the radiator, start the motor and look into the radiator there should be coolant at the top of the opening. If not add coolant while engine is running, note if it's pink it's the DEX/Cool, if green any over the counter coolant will do. Add until the level hits the top of the opening. Let the engine heat up and check the level again. If it's full put cap back on and note the level in the overflow jug. If engine is hot level should be at the top mark, be sure to NOT fill the jug to the very top as it needs the space to expand for any over flow from the radiator.
The system will pull extra coolant from the jug when it's cold and use it until the proper temperature is reached then it will "spit" the extra back into the jug. (that's why there are two lines 'hot' and 'cold') Never add water to the jug as it will cause the jug to crack if the outside temperature goes below freezing always add coolant/antifreeze.
Oct 10, 2009 | 2002 Chevrolet Cavalier Coupe
I have a leak my jug will not hold water or antifreeze i just had the radiator replaced is it my water pump
NO SOUND LIKE COOLANT OVER FLOW JUG HAS A HOLE IN IT REPLACE IT SHOULD FIX THE PROBLEM.
Sep 30, 2009 | 2000 Oldsmobile Alero
Russell Hobbs RHOK3123 Cordless Electric Kettle Logo
989 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Ruth summersides
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
