I HAVE A SONY WAGA TRINITRON KV-30HS420. WHEN I TRUN THE TV ON AFTER BEENING OFF FOR SOME TIME IT WILL HAVE A POPPING NOISE FOR ABOUT 15-30 SECONDS. AFTER THE POPPING STOPS IT WILL NOT DO IT UNTIL YOU TURN IT OFF. IF YOU TRUN IT OFF AND TRUN IT RIGHT BACK ON IT WILL NOT HAVE A POPPING. ANY HELP?
Dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
High voltage
shutdown. The high voltage has exceeded 33k and the unit goes
immediately into safety shutdown. Check power supply regulation and
horizontal circuits.
Hope that points the engineer in the right direction.
