SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
SOURCE: Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
SOURCE: Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
SOURCE: whirlpool cabrio he, wtw6600sw0 with an f50 error
Motor stalled. Remove basket look for objects.
See page 68
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
is there any rollers or bushings that i can replace under the cabinet on the tub to help give it a more stable wash?
it starts out in the spin cylce fine and as the speed increases so does the rock, alomst as if the somethings missing or the suspension rods and spring are severly worn and give too much, is that possible?
