Just bought a new SD card and installed it into the camera, has new batteries, and when I take pictures it saves to the camera and not the mass storage device. I have the twain driver set mass storage as well and it still will not save to the card
SOURCE: how do i save the pictures to see them without a memory card
there is only a 16 MB internal memory built into the camera, which at 5 Million pixels will allow you 1 or 2 photos, so you will have to by an SD type card, i would suggest either a 512MB card or 1GB if you are taking pictures at the highest resolution.
SOURCE: Saving pictures
The camera has a very limited storage space on itself. It probably isnt saving the pictures on the card because the card is write protected (probably on accident)
just pull out the card and on it is a tiny little switch. just push that into the next position and it is no longer write protected. the write protection is there to prevent you from losing your photos, to put more photos on it you will have to deactive the protection with that switch, its usually white colored
SOURCE: camera does not recognize memory card
Did you format your memory card before you tried to use it? Format your SD card in the camera first and see if you still have the problem. Also, check to make sure the switch on the card is not in the locked position.
Rob
SOURCE: Pictures are not being saved on my new SD card.
Hi Greg,
Make sure you format the card in the camera before you use it. Cards won't work most of the time, until you do. Also, check to make sure the switch on the side is not in the locked position.
Rob
SOURCE: when i take a picture it wont save on the memory
THe memory card is either to large for the camera, or needs to be formatted. Put the memory card in a laptop or other card reader and inspect what is on it; save the contents and then reformat the card for the camera by running format.
I had a 4GB card installed so this is the reason why it wouldn't work with the camers
