No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner,
check to make sure there is a full tank of water. If the water level is
adequate, check the position of the gasket on the bottom of the water
tank assembly. The gasket can become lodged, damaged, or removed. If
this has happened, fix the gasket to the proper position according to
the user manual, or replace the damaged or missing gasket.
Change the belt on a steam cleaner that has
inoperable brushes. From time to time, belts on carpet steam cleaners
become worn, and you must replace them. If the brushes on your unit have
stop moving or do not turn on, you may have a damaged belt.
Replace a belt at home easily with little expense. Refer to your
user's manual for replacement instructions and the part number for
purchasing the belt. Remove and replace the belt according to the model
of steam cleaner you own. Purchase a new belt at home
improvement stores or directly
