Model MAV8600AWW Washer loads seem to become out of balance easily. Shut down switch does not stop washer when out of balance happens.
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
SOURCE: frequently off balance and won't spin
Check if the machine is level and if after it has spun, the bowl is in the centre. Remove front cover and inspected all the springs that hold the bowl onto the lower chassis. The bowl should be balanced in a round plastic bowl which is in the shape of a bell. Check if this plastic bowl is worn. There will be pieces of plastic or plastic"dust" all over the bottom of the machie if it is worn. Good Luck.
SOURCE: maytag fav9800aww washer has trouble
If it’s a FAV6800AW or FAV8900AW and you want to DIY a fix take a look at this post and see if you or someone you know has some very basic mechanical skills and can do a clutch replacement or roller clutch bearing re-lube. The dc/UC unbalance errors are a very common failure issue with the FAV6800AW/FAV9800AW clutch.
I have put together a step by step process to perform a clutch replacement process, this repair will get your $1000 machine back in service with a $50 dollar clutch replacement. Worse case you can give the repair person some facts and maybe control cost and speed to repair. I believe you will find you will pay $300 - $400 to have it repaired.
If you pay more than $50 dollars for the clutch you are throwing money away. Clothes Washer Clutch - 25001169
You can try this test just to rule out the TDS as the failure point almost all the time dc/UC unbalance errors are related to clutch issues with this machine model.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Press the Super Wash key display reads “in”…something like that.
Press Delicates the Display will show “UC” (Unbalance Closed).
Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
Press Hand Wash.
Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
We can turn on the drain pump in Service Mode to pump out excess water, let me know if you need help with that. The link I have in this post will send you to the Service Manual on this site in PDF format .
I believe a lot of folks toss this $1K machine when a $50 dollar clutch replacement or an even cheaper a Oneway roller clutch bearing clean up (if the bearings are rust free) will get the machine back in service.
Post back if you decide to DIY the fix and need help.
Good luck… Rich
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
SOURCE: Maytag Atlantis Mav8600aww
I have a maytag atlantis mav8600aww and the machine won't spin and drain water out.
