SOURCE: Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
SOURCE: I have a Singer 2662
There are two details to this that may make a difference in the answer...
The problem I had was that it wound the bobbins too high on one side, so the rubber foot stopped it but it was only half full. So if you looked at the bobbin after it was wound straight on, you saw a slant to one side where more thread was wound. The fix to that was easy - gently guide the thread down with your finger as it winds to make sure it does so evenly. Be careful with the pressure! You don't need much at all to do the job, but if you push down too far it will quickly go right past the bottom of the bobbin and wind on the metal axel.
The second detail is that the rubber foot that is attached to the right of the bobbin spooler on the top of the machine (it has a screw down on it) has been bumped or moved closer to the bobbin so that it stops too early. The best way to fix this is to tighten the screw just a hair - that goes clockwise and should twist the rubber foot with it as much as you tighten. IF the screw is already really tight, then just use your thumb to push that rubber foot out a bit (again, clockwise around the screw post).
Warning: Overtightening the screw will lead to breaking it all together pretty easily, so only use the tighten the screw method if it's already loose!
Make a small move to it, then try winding again. If the wrapped thread extends past the edge of the bobbin, you've adjusted too far and need to bring it back in.
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
SOURCE: I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
