Wrong fuse was turned off when changing light switch covers...screwdriver touched something then sparked then all power shut off....genious. Anyways the main breaker was off obviously but will not reset....and I had a family electrican take a look and he said there's no power to the centre at all. He can't figure out why. There are no other panels or boxes within the unit. This is a condo unit so I asked the caretaker if there was a metere room. He said there was a gas meter room....would there be an alternate power source for the load centre that has been tripped as a fail safe perhaps??
SOURCE: Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
I don't mean to be flip, but if you have to ask, you really shouldn't be doing this yourself. You might need to look this up in the "code", but if you don't already know where to look it up, then you are crossing a big DIY danger line here. Good luck and be safe!
Check amp draw, make sure service calculation was completed correctly, check line side and load side connection of main breaker
