Where is the battery
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
SOURCE: jabra bt125 broken ear hook
You can buy a 5 pack for 6.99 here:
http://www.shop.jabra.com/jabra/Shop?Dsp=30007&PCR=1:401&actn=addkeycodetocart&keycode=5JABRAST400
SOURCE: google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
SOURCE: can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
SOURCE: Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
