Lint filter sensor cuts off machine within 5-10 minutes.
Filter is clean, ductwork clear. Have had "Factory Authorized" service on 3 occasions...they are clueless. Also had a service call from a non-authorized appliance repair company--more wasted money. At this point, I prefer to disconnect the whole "lint checking" system and be done with this darn problem, as I thoughly clean lint filter each time dryer is used. The dryer has been useless for months, and it's getting too cold for a clothesline, especially in light of this unit's original cost!! Thanks. I await your reply. Shotguntherapy.
The issue you are experiencing with your Bosch Maxx7 sensitive dryer could indeed be related to a faulty heat sensor or a clogged vent. Here are a few troubleshooting steps you can try:
Check the vent: Ensure that the dryer vent hose is not clogged or blocked. A blocked vent can prevent hot air from circulating in the dryer and trigger the overheat sensor to shut down the machine.
Clean the lint filter: Remove the lint filter and clean it thoroughly. A clogged lint filter can also cause the dryer to overheat and shut down.
Check the heating element: If the heating element is faulty, the dryer may not heat properly or may overheat and trigger the sensor to shut down the machine.
Reset the machine: Turn off the power to the dryer for a few minutes and then turn it back on. This may reset the machine and resolve the issue.
If none of these troubleshooting steps resolve the issue, it may be best to contact a qualified technician to inspect and repair the machine.
Dryer
Failure CodeConditionCheck/Repair
F1
Condensate drain overfilling
Check condensate reservoir pump and drain tube.
F2
Maximum drying time exceeded (3hrs)
- Check for tripped circuit breaker or blown fuse
- Check ductwork for lint build-up
- Check hi-limit and cycling thermostat
- Check heating element
F3
Thermistor fault
- Open thermistor, replace
- Bad wiring to thermistor
F4
Too much lint in the lint filter, front housing, or in the condenser
Clean lint from lint filter and/or condenser
F5
Fault in the moisture sensor
- Lint covering sensor in front of housing
- Bad sensor
- Bad wiring to sensor
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
I would recommend you have someone take the dryer completely apart and clean the lint out. In the last 3 months, I have cleaned out 2 or 3 shoeboxes of lint from each of 5 machines.
This has nothing to do with the filter screen you are supposed to clean after every use.
It has to do with the lint that escapes the ductwork inside the machine itself.
You may be amazed how much you will find.
You will also need to check the ductwork from the back of your machine to the outside air. That pipe can also get clogged and cause the same results.
Be blessed.
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet. 2
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel. 4
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut. Lint Filter 5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door. 6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction. 7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool. Clothing Not Fully Dry 8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month. 9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door. 10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content. 11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Code AF means the air flow is blocked. Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Sounds like the vent is plugged. Disconnect the vent hose from the vent and test again. If it drys normally your vent is plugged and will need to be cleaned.
VentFrequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.Internal ductworkYour dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
