The name is only on the side(the side opposite the spool side) the decal looks as a low def laser print copy which is just a sticker. there are no setting recommendations in the spool compartment.
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
SOURCE: trying to choose between a
Hobart and lincoln are extreamly good units, it boils down to your personal preference, if possible, try them out ask for a demonstration.
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: my mig wire melts inside base unit when trigger is pulled
Your liner is grounding some place make shure the tip is not touching any thing but the answer to your question is there is a direct short in your feed hose or tip or liner
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
