Instructions
Put on your work gloves. Check the frame size for your mower. It will
either be a 56-inch frame mower or a 76-inch frame mower. When you have
determined the frame size, adjust the tractor's rear wheels to the mower's
frame size. For 56-inch frames, adjust the rear tractor wheels to 56-inch
centers or less. The same rule applies for 76-inch frames.
Back the tractor into a position where you can align its left lower link
to the mower's lift link pin. Attach these two parts together and secure the
connection with the tractor linchpin.
Roll the tractor and adjust the leveling crank until the tractor's right
lower link can be attached to the right link pin on the mower. Use the tractor
linch pin to secure the connection.
Attach the upper link from the mower to the lower hole in the tractor
rocker arm by using the link pin.
Start the tractor. Using the hydraulic control lever, lift the mower
frame assembly slightly and move the mower to the left to allow attachment of
the left stabilizer. Place the stabilizer guide under the tractor's left lift
link. Position the clamp over the link and tighten the nut firmly
Depending on the tractor type, install the clamp plate or push rod
anchor assembly onto the left lower link. Install the push rod on either the
clamp plate or anchor assembly.
Shift the mower assembly to the right to attach the right stabilizer.
Place the stabilizer guide under the tractor's right lift link. Position the
clamp over the link and tighten the nut firmly.
Raise the mower using the hydraulic control, then attach the mower lift
spring to the spring links with the pins that have been provided. Lower the
mower assembly and turn off the engine.
Remove the tractor power takeoff (PTO) cap and connect the splined end
of the mower's drive shaft to the PTO shaft. Secure the connection with the
snap coupler found on the yoke.
Rotate the leveling crank to lower the frame, ensuring that it is
parallel to the ground. Use the leveling crank lock to secure the crank lever.
Thanks, but the manual doesn't show enough detail or give the size for this part, which I no longer have. The closest I can get is Figure #12 in thishttp://www.homedepot.com/catalog/pdfimag...
Thanks, but the manual gives no details on the part, which I no longer have (it may have gone down the reain).
