Zoom error. camera got wet. blew out w/ leaf blower. wet inside lens. I turned lens barrel back by hand . now frozen.
SOURCE: My FINEPIX S1000fd fujifilm camera ZOOM ERROR
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
SOURCE: fuji finepix s1000 zoom error lens is stuck out what can I do???
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
SOURCE: Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
SOURCE: Telescopic zoom lens won't expand
Lens may have jammed.
possible solution : [email protected]
the cause of my problem was my impatience. Batteries out, with barrel out. I turned the barrel back in by hand. Just hard enough, no hard force. Then I was stuck. Barrel in. Zoom error. everything works otherwise. Menu, etc. No focus. I am going to get a S4500. And try to fix my precious S1000fd. The suggestion below may be very helpful. I cannot make my 1000 worse.
the next day lens was dry. I would have been fine. I bought my 1000 in '08. A great camera. Used it alot.
