Cannot find a way to open the printer toolbox to align cartridges etc. I have no task agent icon nor any other indications in all programs to find the toolbox. Printer operates fine otherwise. I used to be able to reboot and the task agent would appear in my taskbar, but does not happen now The printer is a HP deskjet 940c. I share it with another computer with a peripheral switch.
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
Right-click the printer icon to open Properties.
Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
The
following message is displayed. Click 'OK'. Print head cleaning starts.
The power lamp flashes during cleaning operation. Do not perform other
operations. After cleaning has finished, the first head alignment
pattern will be printed.
The following message is displayed. After printing has finished, click 'Yes'.
Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
<1> Example of highly visible vertical stripes in the pattern. <2> Example of the fewest visible vertical stripes in the pattern.
Enter the selected pattern's number in the Column A box.
Similarly, enter the selected numbers in the boxes for column B to F.
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox . Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Checking
ink levelsUse one of the following
methods to check the ink levels.
Method one:
Check the ink levels from the HP All-in-One
The ink level is displayed on the main screen
of the control panel display. Locate the two icons that represent the
print cartridges. The icon on the left is for the color cartridge and
the icon on the right is for the black cartridge.
The
exclamation mark (!
) symbol indicates a low ink level.
The question mark (?
) symbol indicates the product cannot determine the status of the print
cartridge. This might be because the cartridge is refilled.
Figure
1: Ink levels on the control panel display1 - Exclamation mark indicates low ink in the
color cartridge2 - Ink level in the black cartridge is OKMethod two: Check the ink levels from the
computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP
Toolbox.
Make sure the product is on and
connected to the computer.
Open HP Solution Center
Windows XP: On the Windows
taskbar, click Start
, click All Programs
, point to HP
, and then click HP Solution Center
Windows Vista: On
the Windows taskbar, click the Windows icon (
), click All Programs
, click HP
Windows 2000: On
the Windows taskbar, click Start
, click Programs
, point to HP
Click Settings
Point to Print
Settings
and then click Printer Toolbox
. Printer Toolbox
opens.
Check the
ink levels displayed on the Estimated Ink Levels
tab.
Toolbox
The Toolbox provides status and maintenance information about the printer. It also provides
links to the onscreen user's guide for help in performing basic printing tasks and solving
problems.
NOTE:
The Toolbox is available for Windows computers only.
If the Toolbox was not installed with the other printer software components, you can install it
using the installation program on the Starter CD.
To monitor a printer on a shared port (for example, \\portname\printername) from a client
machine, the Toolbox must be running on the server machine as well as on the client machine.
Opening the Toolbox
From the Start
menu at your computer, point to Programs
Point to the printer name, and then click the Toolbox
icon.
Toolbox tabs
The Toolbox contains tabs that you can use to view product information and change
configuration settings.
TabsContentsPrinter Status
Selected printer
The drop-down list displays the currently selected printer.
Ink Level Information
Shows estimated ink levels for each cartridge.
Order Supplies
Provides access to a Web site where you can order printing supplies for the
printer online.
Ink Cartridge Information
Shows order numbers and expiration dates for the installed ink cartridges.
Preferences
Gives you the ability to set advanced Toolbox settings, such as selecting which
printer error messages appear, specifying whether you want to be notified by an
audio alert when an error occurs, as well as the types of error messages that you
want to see. Also, you can turn on myPrintMileage AutoSend, which provides you
with a closer forecast of printer usage on the myPrintMileage Web site.
Information
Printer Information
Provides links to myPrintMileage and shows the printer hardware and printhead
health information. You can also use the tab to obtain information about
accumulated ink and media use, statistics up to the last 20 jobs, and job tracking.
Help Information
Provides links to HP Instant Support and HP Customer Support, as well as to the
onscreen user's guide for help in performing tasks and troubleshooting. It also
provides instructions that guide you through registering the printer onscreen.
Printer
Services
Align Printheads
Guides you through aligning the printheads.
Clean Printheads
Guides you through cleaning the printheads.
Calibrate Color
Allows you to calibrate color manually.
Print a Demo page
Prints a demonstration page. This is used to verify that the printer is connected to
the computer correctly and that the printer and printer software are working
properly.
Advanced Configuration
Allows you to set tray lock and select a default tray (if Tray 2 is installed).
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.) Click Start, then Printers and Faxes. Click the desired printer icon to highlight it. Click File, then Printing Preferences. Click the Services tab. Click Open Toolbox. Click the desired task. Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer) Click Start, then Printers and Faxes. Click the desired printer icon to highlight it. Click File and Properties. Click the Services tab. Click the desired task. Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer) Double-click the XXXX Printer Assistant icon on the Desktop. Click the Utilities button or the Tools and Updates button. Click the Printer Maintenance button. Click the desired task. Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer) Right-click the Printer icon on the Taskbar. Click Open Toolbox. On the Device Services tab, click the desired task. Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer) Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox. Click the Device Services tab. Click the desired task. Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges: (NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer) Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant. Click the Utilities button or the Tools and Updates button. Click the Printer Maintenance button. Click the desired task. Option 7:-Double-click the HP Director icon on the Desktop. Click the Utilities option. Click the Printer Maintenance button. Click the desired task.
