Comprei uma isuzu bighorn, mas não tenho o seu manual de utilização, será que alguem me pode ajudar enviando uma copia para o [email protected]
Ive got an Isuzu Bighorn 3.1 model 1997, them I am looking for a owner mannual written in english, coz the exist mannual is writting in Japanise. please help me send a copy to [email protected] so i can better utilize my dream car.
please post in english his is USA forum. and is english only. here ill use google translate for you. My truck Isuzu no longer running and turn off the computer turns my marks a po342 code that may be the position sensor of the tree cam d put it back and continued the same. which can be another.
Ok , P0342 is clear in the book, (but you never said engine type in car>? so......) here are the possibles. 1: CMP sensor dead or bad. 2: cam timing way off. (is compression TEST over 150 PSI on all cylinders? (no engine stated, so.... cant tell you why see? 3: bad wiring to the CMP. 4: or CMP timed wrong.
CMP is the name of the CAM SENSOR. BTW. no car stated. no year stated. no engine stated no country, yes, cars do vary greatly by , COUNTRY. mostly hopeless so for...
use google translate to translate ENglish back to Spanish.
to do so type, Translate in the google box and magic happens.
The vin # does not get higher as the year goes up, the vin # each number has a meaning to it, for example body code is one number then year then engine type and so on, it does not start at 1 and go up as the years do, hope this explains it good day
okay si gasta mucha gasolina puede ser que tus sensores de oxigeno esten mal. o tu regulador de gasolina siendo que si la presion de gasolina es muy alta esto hara que los injetores se injecten mas gasolina de la necesaria. Hacerle los servicios a tiempo es otro factor importante para un consumo normal de gasolina. Cambio de aceites bujias, pcv valvula filtro de aire, tapa del distribuidor y rotor. acuerdate un motor en buenas condiciones necesita menos gasolina para mantenerse en movimiento un motor mal cuidado requerira de mas fuerza y para lograr fuerza requiere de mantener el pedal de gas mas a fondo con mas tiempo. Revisa tus llantas tambien. Llantas con falta de aire hace que el auto gaste mas gasolina porque aceleras mas para que el carro avanze.
No se te olvide calificar me por la ayuda que te he brindado.. gracias.
utilizar10W30de aceitey unfiltro deWiX.Ell?quido dela transmisi?nse comprueba y sellenaa trav?sdeltap?nde drenajesuperioren la parte inferiorde labandeja dela transmisi?n.El l?quidotiene queserbombeadaenmientras se est? ejecutandoycalientehasta queempieceaagotarse.TomaATFDEXRON
El juego de Volante lo puedes ajustar, desde las ruedas hasta el volante....es necesario que sepas que el volante tiene un juego libre a la DERECHA de 2.5 cm y a la IZQ 2.5 cm...es normal...mas de este es ajuste....
GRACIAS por tu pregunta....
SAAED COSTA RICA
Normalmente en este tipo de cajas se daña el cuerpo de valvulas. pero hay que determinar exactamente lo que es, si quieres mas informacion escribeme a transeggo @ hotmail.com
