Hi Naidoo.
not sure if this forum will help you out but have a look.
K800i inactive sim
plus found this on the internet.
it may be the software needs reloading, if you download the "sony ericsson pc companion" to your pc you can connect your 800i by usb lead, then click on the companion panel for updates, it will give you the option to repair phone, select this option and all your software will be renewed. or if you prefer to contact orange first just go onto their website and the phone numbers will be there.
(AND THIS)
U just istall p.c. suit of sonyerricsson and take backup of ur data,, then u need to flash ur handset from sony erricson service centre.
OR THIS MIGHT HELP.
sony ericsson k800i inactive sim problem Google Search
SOURCE: INACTIVE SIM
Sounds like a silly question but did you update the phone via the SE suite or via a flash updater? there may be problems if you left your sim in, if you flashed the phone. If you updated via the SE suite then take a look at the troubleshooting guide and moan to SE. As long as you haven't voided the warrenty on your phone there should be no problem with SE or your service provider repairing your phone for free. :)
Hope this helps. One last thing to try is to out another sim in the phone and see if it works. With any other provider except O2 you will need to use a sim the same as yours.
SOURCE: inactive sim
I have the same problem since I got O2 to block my phone when i lost it. Now it's found it says "Inactive SIM", even though the SIM works in other phones.
SOURCE: se k800i dead
Try updating it with Sony Ericsson Update service on the sony Ericsson site using your data cable. I did it with a clients phone...
SOURCE: k800i phone
Charge it over night, Replace the battery or update the firmware useing a sony ericsson update.
I have had an inactive sim card since Friday. Despite removing it and cleaning it (god nows why) it still displays the same. I am unable to top up either as the reply I get is technical problems. As a PAYG customer what else can I do?
Al
