Question about Yamada DVD-5520 DVD Player
DVD not playing disc
I have connected the Yamada DVDSlim 5520 to my TV using a Scart.I also tried connecting it through coaxial cable(From coaxial output of DVD to TV aerial input(RF input)socket.When the tray is closed,the disc starts loading for a moment (as indicated by the display window) and stops. Doesnot play disc when the play button on the front panel is pressed.Nothing happens when you press the Previous/Next buttons.I have misplaced my remote control - hence have to use manual buttons on Front Panel of DVD. Do I have to select a specific TV channel (AV1/AV2)to view disc being played?
2 Suggested Answers
SOURCE:
otacon
  • 1950 Answers
SOURCE: DVDslim 5520
You can download the manual from here.
Posted on Dec 30, 2007
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
What channel does tv need to be on to play dvd's
Hi and welcome to FixYa,
Depending on where you are and the standards/connections used, it could be:
  • Channel 3 or 4 (if using a single coaxial patch cord);
Other connection possibilities are:
  • AV, Video 1, AUX, Line 1 (if using composite yellow red & white RCA to RCA cables);
  • Component (if using component Y, Pb, Pr, red & white RCA to RCA cables).
  • SCART;
  • HDMI;
  • S-Video.
Perhaps you could post back what is used, what connectors are available at the rear of both the DVD player/TV.
Good luck and thank you for using FixYa.
Feb 14, 2009 | Samsung DVD-VR357
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | Televison & Video
How can I unlock a dvd to play dvds from all regions, I understand that by entering a code it can be done. The DVD player is Yamada dvd slim 5520
  • Download the firmware update from:
  • http://www.umax.de/cgi-bin/treiber.pl?DVD=Y5520&Scanner=0&OS=0&SCSI_Karte=0&DigiCam=0&D_Form=Suchen+%2F+Search
  • Extract the file to your hard drive and burn the 11121213.BIN to the root directory of a CD. Use Standard ISO9660 Format and finalize the CD. Don't use Joliet, multi-session or XA Format!
  • The CD title must be P80J0001. Don't copy both firmware versions on one CD. You have to use separate CDs.
  • Insert the ready CD into the DVD-Player and press Play when prompted.
  • When the CD drive opens take out the CD and wait about 1-2 minutes.
  • The DVD player will be reset automatically
  • Mar 07, 2008 | Yamada DVD-5520 DVD Player
    DVDslim 5520
    Dec 30, 2007 | Yamada DVD-5520 DVD Player
    Yamada DVD-5520 DVD Player Logo
    62 people viewed this question
    Top Yamada Televison & Video Experts
    Damen Wong
    Damen Wong
     Mike M
    Mike M
    Are you a Yamada Televison and Video Expert? Answer questions, earn points and help others
