I was printing on my wireless printer when it stopped and gave error code 0X0005FBB6. What does this code mean and what can I do to keep this from happening again?
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
SOURCE: HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
SOURCE: Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
SOURCE: HP C5180 PRINTER ERROR
Hi ok try
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Hp Deskjet 1050C Plus- Print head error
It is not unheard of to have a bad print head out of the box. I suggest you remove all the print heads and clean the ribbon connectors in the carriage that connect to the print heads. Clean the connectors on the print heads also.
If that does not clear up the problem, you may have a bad trailing cable (carries all the signals to and from the print heads) or a bad carriage.
Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Download Service Manual: www.lpscomputer.com/ec/manuals.htm
