I have a supertooth btslbc3 that has worked fine untill yesterday. It is now asking for a pass code to pair with my Nokia 6103 phone. I have no book with this device and no code available can any one help?
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
thank you
Thank you sooooo much. I searched the net for hours before finally stumbling onto your instructions which fixed my problem in moments!!!!
Thank you for this ! I have hunted for the answer and it was perfect !
Awesome Im up and running. Thanks heaps
Yes it was, thank you very much, saved me alot of heartache
Thank you for the solution. Denis
Appreciate it friend
thanks for that
Probleme resolue avec clef d'activation "0000" merci
How do i pair the supertooth model number,btslbc3,with my iphone3gs 16gb
Many thanks for all your help all OK now
does blueant work with verizion env2
supertooth btslbc3 pairing with 3g iPhone
