Sounds like you're grounded out somewhere. I'd check your main power wire again, make sure there isn't any abrasions or cracks in the insulation. I had a Fosgate amp that would blow fuses everytime they were put in. turned out to be one of the screws to mount the amp to my floor board was grounding it out, pulled the screws and has worked fine ever since
so your saying to check my wire running from the battery to the amp and go down the entire line? because my wire runs directly beneath the floor panel all the way to the back with no screws or anything involved
Yep, even a little nick in that line can cause a short if the copper wire on inside the insulation touches any metal anywhere on the car. and when you say under the floor panel do you mean tucked under the carpet or run underneath the car? Run under the car increases your chances of damaging the power cable if not properly attached away from heat, moving parts, or tucked up high enough to keep it from getting snagged on road debris.
the panel thats basically the pplastic where the door closes but its on the floor inside the actual car next to your feet pretty much, its hard to describe.
SOURCE: AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
SOURCE: car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
SOURCE: im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
SOURCE: is my amp getting burnt out, it keeps blowing fuses
sound like you have a a bad spkr connect the spk one by one to amp and play the system and you will know and make sure the spk can handle the load from the amp too''
