Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
A
Anonymous Posted on Apr 17, 2017
Cabrio dryer end of cycle signal doesn't work
I have a cabrio dryer and when the buttons are pushed to start a cycle they do not sound. The end of cycle signal doesn't work consistently either. It's hit and miss...sometimes it works, more often it doesn't. I have to keep checking to see if a load is done, and sometimes it's done and I miss it, then have to fluff the load to remove wrinkles (using more electricity, of course). This dryer is less than a year old, so it really makes me angry that I'm having issues already. Otherwise it works fine...I just hate having to use the additional electricity to redo the loads I miss.
  • Official Brand Answer 408 Answers
  • Posted on Apr 18, 2017
Whirlpool
Level 0:
Answers
408
Questions
0
Helped
157844
Points
784
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your Dryer.
  • Whirlpool
    Whirlpool Apr 18, 2017
    Hello, we are sorry to hear of the problem that you are experiencing. You can check the use and care guide to make sure that the end of signal sounds are not turned off. If the problem persist you can send us your name, phone number, address, model/serial numbers and the date of which you purchased the dryer to [email protected].
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Dec 10, 2007
SOURCE: Whirlpool Duet Electric Dryer (5yrs old)
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
John Morganti
  • 864 Answers
  • Posted on May 29, 2009
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Anonymous
  • 27 Answers
  • Posted on Jun 15, 2009
SOURCE: I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
dray8165
  • 15 Answers
  • Posted on Jul 20, 2009
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Anonymous
  • 710 Answers
  • Posted on Sep 22, 2009
SOURCE: My dryer won't start, but I think the cycle button won't engage.
THERE IS A SWITCH THAT IS LOCATED ON THE OPPOSITE SIDE OF THE DOOR. SOME OF THESE SWITCHES ARE OF THE PLUNGER TYPE. TRY PUSHING THE PLUNGER IN WHILE STARTING THE DRYER, MAKING SURE THAT NOTHING IS IN THE PATH OF THE ROTATING DRUM. IF THE DRYER STARTS, THEN EITHER ADJUST OR REPLACE THE PLUNGER SWITCH. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. GOOD LUCK
Does the Amanda dryer NED4655EW1 have an end of cycle beep?
Yes, it does.
PUSH TO START/END OF CYCLE SIGNAL The End of Cycle Signal produces an audible sound when the drying cycle is finished. Promptly removing clothes at the end of the cycle reduces wrinkling. Turn the END OF CYCLE SIGNAL knob to select the desired setting (On or Off). Press the PUSH TO START knob to start the dryer.
Page 5 of the User Manual
https://www.amana.com/content/dam/global/documents/202003/specification-sheet-ned4655especsheetv01.pdf
Jan 21, 2022 • Dryers
2answers
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 • Dryers
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
I have a T711 asko dryer. When I push the start button it makes the sound when the dryer has completed its cycle. There is a "signal" button that you can depress to let you know the dryer is finishe
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shieldâ„¢ Plus Feature is preset to on during the permanent press cycle.
Can the end of the cycle the buzzer be turned off?
On the display panel under the start button is a signal indicator. If you push the button to the left of the indicator you should be able to reduce the volume and even turn it off. The button on the right of the signal indicator will bring the volume back up.
Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
