How to sole this problems
SOURCE: P4M80-M4 not powering up
was that really all it was ? i have the same problem you had... computer not booting with this motherboard. I have tried everything !!! remove battery to clear CMOS use the jumper to clear the cmos change the keyboard, change the PSU, boot without RAM, change the RAM, put everything on a wood table (all outside of the case). Tried with all drives connected on the mobo, tried with no drives. I even changed the CPU but the other CPU i used, i wasn't sure if it was still OK tough. I checked to see if some connections were broken or something ... i'm about to try to find the 1-800 number of biostar, or send the mobo for a refund. What else could i try ?
SOURCE: Problem with my Audio Driver
Here are the drivers for your board. Download the audio driver for your operating system.
Please vote if you found this information helpful.
Thank You
SOURCE: Only the cpu fan spins
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
If I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard lights are out and (wonder!) I can start the computer again in a normal way.
Can this one be a temporally solution for you too?
I guess that can be electricity dysfunction of a wrong fixed cable.
SOURCE: dont know where to hook up the power and leads on
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
I need more info. Can you please let me know the Operating System installed on your system? Also, are you sure that the Audio Driver is installed? Your response is necessary to receive the answers. Thanks.
