Steering is hard to turn when not driving..
Hello! There are power steering fluid in/out hoses but no vacuum lines...It sounds as if the pump needs to be bled of air or the belt is loose...Belt should move about 1/2 to 3/4"...Bleeding is as follows...
Guru...saailerImportantPower steering fluid level must be maintained throughout bleed procedure.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
SOURCE: driver side power seat 2001 Chevy Tahoe
as long as nothing is stuck in track and you hear no noise when using switches, look for broken wire at connector or in harness. ck fuse first of course, if blown, something may be stuck in track causing it to stop and blowing fuse
SOURCE: power steering and power brakes failed
Check to see if the power steering reservoir is full and the belt is intact.I'm assuming that you have a hydroboost unit where the p/s works the brake booster. If those are ok you could have a bad p/s pump
SOURCE: 2001 chevy sylverado 2500hd power steering and power brakes quit
check power steering fluid. first. if all good . power steering is going. your hydro boost brake system depends on the power steering pump if it goes out your brake go out.
SOURCE: fuel pump 2001 Chevy Tahoe
no there is not. the only way to access is to drop the gas tank down.
SOURCE: is there a huel reset on 2001 chevy tahoe
Sorry there is no fuel pump reset on the Tahoe. If you have no fuel pressure, check the fuses and relay,and wire harness to the fuel pump from the inside frame rail on the drivers side. If you can hear the fuel pump working, check the fuel pressure at the shredder valve and there should be 60 to 66 PSI, if you don't you can try checking for 12 volt at the fuel pump wire harness at the frame rail. Good luck and keep me posted, be glad to help.
