My one note program won't open. I have tried uninstalling/rein stalling. I renamed the back up to no avail. I can't see the file onenoteofflinecache
I suppose it must be onenote data corruption, in such case make use of tool below OneNote Fix Toolbox must assist you.
SOURCE: Problem with Onenote 2OO7. Inserting a file as a printout.
Inserting a pdf file into a file won't work because Microsoft files can only read them as an attachment. There were some licensing squabbles between Microsoft and Adobe which caused this to happen. You can do it if you can scan them as a tiff file.
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
