SOURCE: No audio from EMU 0404 soundcard
Go to patch mix application, set the internal clock to 48 kHz
SOURCE: emu 0404 sound card - no output
Try company that made the sound card http://www.zzounds.com/item--EMU8803 look there they may have a solution apparently there is a partition going around asking them (the Company) to revert back to the old standard of the card?
SOURCE: emu 1616 will not run on my pc
MONFICAT - What service pack are you running, under Windows XP? Are all Windows updates installed? One thing you may want to do is (after making sure all Windows updates are applied), uninstall and reinstall the E-mu software, as directed in the manual. When reinstalling the software, make sure you follow the instructions in the manual. You MUST follow the instructions in the manual, else the software will not install properly. Good luck with it!
SOURCE: E-MU 1616. Problem installing drivers
"I am running windows XP proffessional 5.1 on a HP (compaq) dc7600.
Could this be the problem?"
It could be. Bring up your system properties box (Windows key + Pause/Break key). Is that the version shown at the top right on the GENERAL tab?
Is there some reason you have not installed service pack 2 or 3? Of course if you're running an illegal copy of Windows you can't, but I mean any legitimate reason? If we can eliminate the problem with installing the latest service packs we can move forward.
SOURCE: Emu 0404 stopped working
If you reinstall the drivers (2.1) and reboot, your sound should come back. I have to do this occasionally. Am actually trying to find out what the heck is causing the problem... reinstalls take time. But you don't need to move the card at all.
