The light in the phone is out of contral. it should be fixed .
garden led lights
SOURCE: LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
SOURCE: flashing light
It sounds as if that particular extension is in Do Not Disturb.
From that phone, try Feature - 69 - Feature.
SOURCE: Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
SOURCE: HOW DO I GET THE ELECTRA ELITE IN MY OFFICE TO
you need to acces program mode and change 4-01 to assign ringing for the extensions you want to ring. ldtsnj.com
