First had error message 5100. Next an obstruction. Got the obstruction figured out. I was able to print a few sheets and then got error message 1841.
SOURCE: Canon Pixma MP470 Need to print
You have to go to the printer tab and there is a tab about properties
Go to that window and there are so many tabs try go one by one and you will get the answer for this
SOURCE: Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
SOURCE: error 5100 all the time!
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Dont Forget say thanks
All The Best: Pineworks
SOURCE: Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
