Televison & Video Logo
Anonymous Posted on May 03, 2012
How to off child lock off in my panasonic tv without a remote?
Iv lost my remote there is a child lock on my tv i set on my front key on my tv iv found the child lock there but i connot on.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on May 03, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005388
Points
237762
You can't unlock it without its remote control.
How to remove child lock on Panasonic tv
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock to many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
3helpful
I want to unlock the child lock key on my LCD TV
Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
1helpful
Iv lost the remot for my nec cromavision flat tv and the child lock is stuck on
Just check an other code from the remote catelogue for NEC. Some codes might not work all the functions to TV.
17helpful
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
4helpful
2answers
How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Panasonic cyclops 14in'
how can i unlock child lock on panasonic cyclops without using the remote
8helpful
3answers
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
2helpful
2answers
Magnavox 27MS343S 27" TV
You will for sure need to borrow a remote from someone to do this. But I will give you the way to unlockit just in case you can get one. Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
