Computers & Internet Logo
Jamie Levine Posted on May 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get my laptop to work
It just goes on
Anonymous
Level 2:
President:
  • Expert 739 Answers
  • Posted on May 03, 2012
Anonymous
Expert
Level 2:
President:
Answers
739
Questions
Helped
182650
Points
259
Hi. to make your laptop working, you need to install operating system and other software into your laptop to make it fully functioning.......
My laptop turns on but it goes to the main screen and it shows the HP logo, the goes off and goes back to the HP logo. It does it over and over again. Help.
turn on laptop press and release continually F8 key if a screen comes up select Launch Startup Repair choose any option you think may work
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email [email protected]
1helpful
My laptop doesnt charge propely
the charging port in the laptop is either loose or has a bad soilder on it.
1helpful
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
My laptop won't turn on. It goes past the logo screen then goes blank.
shut down the laptop and start it again...immediately start hitting f8 key..select option ....safe mode....
if it works go to start .accessories and system tools and restore the system to previous date where in it was working fine..
it should be able to work perfect then
1helpful
When i start the laptop it lights up bus goes
re seat the memory cards, clean the metal connector with pencil eraser if necessary. If it won't work it might happen that the mem card defect
1helpful
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
2answers
Screen goes green jiggle the screen and it clears up
tienes un problema en el la cinta flex de tu lapto tambin puedes tener soldadura fria
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
