Question about Dell XPS M1330 Notebook
ACPI\PNP0800\4&15ECBBED&0 Unable to boot into Windows. This is the last driver to load (from setupapi.app.log). Computer starts to boot with splash screen then freezes partway through the Windows four color icon. Tried bootrec.exe /fixmbr and /fixboot which get me to the screen "Repair your computer". However, once there trying any of the choices takes me to another screen where there are only two options: 1. start repair of your computer (not exact wording but something to that effect); 2. Start Windows. Trying either one takes me on a moibus loop. In the first instance the screen darkens for a few seconds and brings me right back to where I started. In the latter case Windows tries to start but fails at the logo as described above. I've also tried the 'offboot' scannow option. Yes, I know, some will give me the answer I've already received from several: reinstall Windows after copying the data to another drive. Of course, I've done the latter. But, that simple solution ignores the fact that there is a solution albeit a more complex one. Thought there might be someone on this forum with more than a rudimentary grasp of the issue who can offer an understanding of the issue and a resolution beyond the simple course. It is a challenge!
  • Dell Master
  • 6,771 Answers
Unplug power adapter from computer, remove main battery, now press and hold power for 2 minutes in an attempt to reset.
Posted on May 03, 2012
  • Mike Todd May 05, 2012
    I am not sure how this helps what is an obvious software problem. Would you clarify.
  • John Cunningham May 05, 2012
    This fixes a lot of issues when it comes to startup issues and getting windows online, this procedure will not hurt your computer can save hours of reloading and updating windows along with other additional installations.
SOURCE:
SOURCE: Dell Studio 1537 will not
Having same problem but less tech savvy than u. Any solution found?
Posted on May 04, 2011
SOURCE: Big issues with Vista on my Inspiron!
Did you try to "Restore this computer to another point in time"? Then you press F8, and choose "System Restore" then another screen asks if you want to go to safe desktop, or do a system restore, when you select system restore,another window, a bit like a calendar, and you choose a date prior to when you had problems?
Otherwise, please try this... when dell screen comes up on keyboard hit CTRL+ F11 twice only then you will see Dell pc restore by Symantec.Hit on restore and hit on i agree and select the option Restore the pc to dell factory settings and then it will restore the pc.
Otherwise you will have to obtain a Windows Vista install DVD, boot on this and repair/reinstall from That.. anyway try whats proposed and get back to me..
Posted on Feb 26, 2010
bob_computer
  • 3153 Answers
SOURCE: UNMOUNTABLE_BOOT_VOLUME
when you switch on start pressing F8 repeatedly until you get the boot options.
Choose "SAFE MODE" and continue from there.
You will be asked to continue just before windows starts select "YES"
Now go into your control panel and elete the offending drivers etc.
Restart the laptop.
As for your overheating issues
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on. .
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand if you remove it at all.
Posted on Sep 30, 2009
  • 3940 Answers
SOURCE: We are trying to upgrade
It sounds like the New 2GB RAM module is either faulty or incompatible.
From your notes it appears the system functions fine with the original 2GB module and 1 GB module. Have you tried replacing the original 2 GB module with the New 2GB module and see if you have the same issue? Also will the system boot with just the new 2GB module?
Recommended ram for that system is: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Posted on Jul 19, 2011
  • 30 Answers
SOURCE: "Windows failed to start. A
It sounds to me like the harddrive has errors on it. First, I would try completely reinstalling windows with the windows disk. If that does not solve the problem there are several pieces of software that are much stronger harddrive repair solutions than the built in Windows one. Try this one, it is free for 10 days. You will need another computer (friend's computer?) to download and burn this software onto a CD, then put the CD in your computer and boot to it by pressing any key when it asks you to.
http://www.ntfs.com/boot-disk.htm
Posted on Sep 03, 2011
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I have a windows media center edition 2005 edition pc that had a new hdd installed and OS, programs, drivers, etc loaded up. Its an HP m7674n desk top. The issue is that I'm still missing one driver -...
I have the same issue but with 7250n, I have not found a solution yet. ASUS P5LP-LE , p4 2.8, 1g RAM, ASUS video card. palazzo.mark@yahoo.com
do you think it is worth $ to get recovery disk from HP?
Dec 15, 2010 | Computers & Internet
How do i reboot my computer my self.
Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows operating system before Windows Vista, or select the right arrow in Vista. Select the "Restart" option. 2.)Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer. 3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on. 4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder. Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
All the Best!
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Dell XPS M1330 Notebook Logo
364 people viewed this question
Ekse
Clive
Clive
