Question about Whirlpool GHW9100L Front Load Washer
Duet washer ghw9100lw1 basket has worn the edge of front tub sect
During normal spin cycle with 7 pair of jeans a abnormal thud was heard and upon completion of cycle it was noticed the metal basket made contact with the front section of plastic tub. it appears the edge of the tub had been rubbed all the way around until it melted a 1/4" or mor away leaving pieces in front seal dain area. until this event no abnormalities were noticed. upon disassembly the basket / axil/ bearing seem to be tight and in good condition. shock absorbers feel like they are in good condition as well as side springs intact and secure. unsure of which way to proceed next or the cause of this condition.
  • 2 more comments
  • bobby_weeks Nov 21, 2008
    once again this is a 04 whilpool front loadind duet machine. stainless steel basket, axil, bearing are tight. belt sheave is tight and in good condition. something worn or melted the edge of the plastic tub. has anyone experienced this condition?
  • bobby_weeks Nov 25, 2008
    sorry guys but as i said, all is well on the support system as well as the bearing/pulley assembly. upon disassembly i found the spider arm/drive shaft cracked due to corrosion. this caused the spider arm to flex and send the basket in a wobble condition and thus rub the front outer tub rim. does whirlpool know about this potential failure? cast aluminum does not like oxidizing detergent.
    well i indeed apreciate the help from the last tech. however note that the other helps were probably good but they were not for this particular machine. maybe i did not explain the problem or identify the machine clearly? in any case i am satisfied and would probably use this service again.
  • Debbie Saltzman
    Debbie Saltzman Sep 21, 2014
    This is just happening to mine now Bobby...how did you fix yours??
    Genius:
  • 2,035 Answers
There is no recall on this model by Whirlpool .You contact the customer service get it check if this part as warranty as this due defective part in the washing machine by the company...Please use this link to warranty guide :
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Warranty%20Page%20-%208181901-W.pdf
In case you wanted the part you use this part list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208179877.pdf
Good luck....
Posted on Nov 25, 2008
  • Whirlpool Master
  • 19,396 Answers
Check that all the struts and the springs are present and in good conditions.
Posted on Nov 21, 2008
    President:
  • 1,952 Answers
Open the door, look at the 6 o'clock position of the rubber seal now feel underneath it. You'll find a spring there. Use needle nose pliers and grasp the spring there, pull and remove the spring. Now peel the boot seal back from the 3 o'clock position, don't take the boot all the way off... just enough to give you access to the lock. Now remove the 3 screws holding the lock in place. Gently pull the lock assy out through the opening. Remove the wiring, discard the broken switch assy, wire up the new one and install it.
Make sure to get the boot seal back in place properly and that the spring goes back on just the way it was before you removed it.
Posted on Nov 19, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 22, 2008
    Remove the three bolts securing the inner tub. Next the boot and then
    the 6 bolts securing the transmission to the baseplate. While waiting
    for the seal, remove the motor and clutch and clean it well.
    Genius:
  • 1,239 Answers
Hi
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
6ya staff
SOURCE:
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Feb 13, 2012 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet Washer GHW9100LW1 symptoms of knocking noise during spin cycle. Efforts so far: checked shocks manually and observed during spin cycle and no excessive movement. Drum drive pulley:...
Always worth while adjusting the 'balance'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 01, 2011 | Whirlpool GHW9100L Front Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
During the spin cycle the machine made a loud thud and now during spin cycles the machine pounds and slams yet when the machine is off the basket spins freely and without obstruction... any suggestions?...
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer spin cycle makes noise
if it was from a heavy load more than likely 2 screws came off of the tripod on the back of the metal basket.
take of the front lower panel of the washer and clean out the drain pump, if the screws came out they should be in there. to actually fix the problem you would have to take the entire tub assembly out and apart to get to the baskside of themetal basket.
but in general, its not that hard to fix if you are mechanical savvy. i fixed mine myself and im a 27 yo female who has never looked inside a washer before this experience.
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Nylon or plastic bushing around tub breaking down
sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
Apr 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
291 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
