I have a 2 day new s9 headphones... and after charging them i cant still turn ir on... when i plug it in the light turns green and then it rapidly turn red, it stays on for like 10 seconds and turns of again... I read form right here to do reset (didnt work) or press the on botton and plug it at the same time (turns a purple light on and thats it, doesnt turn on or charge or anything)... please I need >HELP!!!<
SOURCE: motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
SOURCE: They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nico
This site doesn't help with this sort of thing but others have found solutions on XDA developers for this sort of thing. I don't endorse it but it may work.
Motorola Support
SOURCE: My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Testimonial: "It´s been plugged since last night and still nothing"
