How do I get the piston and rod assembly into the cylinder assembly? do I need to oil or grease it? there is two rings at the start like springs, and the piston and rod won't slide down in the cylinder.
Many small hobby machines have a chamfer at the cylinder base to act as a leed into the cylinder, just make sure the piston rings are located properly, there will be a small peg in the piston to stop the rings rotating, the open ends of the ring should be cenral to this pis so as the ring compressis, if there is no leed in the cylinder you will need to use a ring compressor, these can be purchased in kits are are fairly inexpensive, make sure you oil both piston and bore before assembly.
