HP Laserjet CM 1312NFI Color Printer Logo
deeznuts Posted on May 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cb540a chip reset
How to reset chips
Ben Darden
Level 3:
  • Master 984 Answers
  • Posted on May 02, 2012
Ben Darden
Master
Level 3:
Answers
984
Questions
0
Helped
313453
Points
3004
Improve the FixYa experience for everyone by voting!
Have you installed a non-HP toner cartridge? If so, you are probably going to have to install a 'smart chip'. They are readily available.
However, I want you to try a little trick that may work: Hold down ONLINE while turning on the printer.
If that doesn't do the job, you can examine this source for a smart chip by CLICKING HERE
1 Related Answer
Anonymous
  • 240 Answers
  • Posted on Jan 15, 2010
SOURCE: Can I reset the chip to use remanufactured ink?
As the owner of a Cartridge World I can tell you that there is not currently an effective way to reset or replace the chip for HP 564 series cartridges. One of our supplies is hoping to have a solution this quarter.
Testimonial: "Saves me from wasting the money!"
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
2answers
How to reset toner of samssung laserjet scx4200 after refill
usual the reset will be done automaticaly when you renew the cardrige (from samsung) hte new chip on the cardrige will giff the information to the computer and it will be reset. If you purchased the cardrige from an refilling stor they need to replace the chip also but some times they do not use the right chip so there are some informations missing and the computer can not reset, ask the store keeper to attach the right chip for your samsung printer.
2answers
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
7helpful
4answers
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
2answers
How to reset chip economically
Economics - cheaper to clone the chip, than to spend time and resources cracking the Dell "code." Cartridges are $20.00 each on eBay, is that not cheap enough?
1helpful
Ssc4.3 resetter can t reset cx2900,please sent me new version ssc
The SSC utility can't reset any of the modern Epson printers chips, only the waste ink protection counters. For the fill level chip you will need a chip resetting tool, which you can buy very cheaply on EBay - have a look at these:
http://computers.shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fCamerasPhotoQ5fPrintingQ5fPrinterInkCatridgesQ5fJN?_nkw=epson+chip+resetter&_sacat=58058&_trksid=p3286.m270.l1313&_odkw=chip+resetter&_osacat=58058
1helpful
Hi How i could reset my epson r230 printers chip? thx in advance
the printer chip cannot be resetted but the device to reset the cartridge chip is available in the electronics market its called compitable epson chip resetter for cartridges.
1helpful
2answers
Reset chip
could you be any more vague?
k24674
Grand Canyon Tech
Grand Canyon Tech
