SOURCE: Please show me step by step on using the Lexar 2GB
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
SOURCE: i dont know how to save a writing piece
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: lexar jumpdrive firefly 16GB I've deleted
First of all try a data recovery program such as Wondershare Data Recovery to get the deleted files back. Get the program here,
Data Recovery Windows (for Windows OS)
Data Recovery Mac (for Apple Mac OS)
Then format the pen drive from Disk Management if you are running Windows.
Remember - Do NOT try & write anything back to your pen drive until you can recover your data safely!
