The ringer on this extension is turned "off" I want to turn it "on"
SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
SOURCE: turn off ringer on an extension?
If you have a Strata CTX phone system you need to call your dealer unless you have the software program then I can help you.
SOURCE: Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
