Always comes up limited or no connectivity
need network key
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
7) Also this issue is relate to SP2 update (in that case you should run the Microsoft patch (KB884020) for it.)
Desktop computers are not known for their wireless connectivity, but it is possible to make yours one that is.
Wireless network adapters, which enable your desktop to pick up wireless Internet signals, come in a variety of forms, and are all fairly easy to install.
Once you have one installed, getting online wirelessly is almost effortless.
Choose the network adapter that is right for you.
The easiest network adapters to connect do so via USB, but if you have limited USB ports on your desktop, you may want to try another option.
There are also network adapters that plug into your Ethernet port, but if you want to use that port for a landline connection you have, and wireless is your backup, then this also may not work for you.
If that is the case, you can buy an add-in card, which fortunately for Dell owners is very easy to install.
Dell computers are designed to be opened and have add-in cards installed without the use of screwdrivers; check your manual for details.
Install the network adapter and any included software.
The adapter will usually come with a software CD with a notice to run the CD either before or after you have plugged in or installed your adapter.
Go through the setup steps on the CD, click "Finish" when it is complete, and your wireless network adapter should then be activated and ready to receive wireless signals.
Click the notification that pops up letting you know that wireless networks are available; or, if there is no notification, go "Start > Connect To" and all available networks will be displayed.
Double-click on the logo for the network you want to connect to and enter the security key if it is a secure network.
(If you set the network up, you should have the security key saved somewhere with your network settings.
If you are connecting to a nearby hotspot, you will need to ask the permission of whoever set up the connection and obtain the security key from that person.)
Select "Home," "Work" or "Public Location" when prompted to designate what type of network connection this is.
You will then be asked if you want your computer to remember this computer and start it automatically in the future.
If you plan to use this connection regularly, it is a good choice to check the boxes next to both options so that the connection will always be available and you won't have to enter a security key for it again.
Hope this helps.
desktop, windows xp
wireless started aug 21 every time i want to use the computer have to log off and log on to get the internet. Wireless is explore net. I have a modem and d-link in one room and the desktop in another room.
It always tell me network key, limited or no connectivity and then i have to phone for support and they have me pull the d-link and shut down the computer to get my internet.
