I just purchased a used 2035G. When I tested the unit the duplexing worked just fine. NOw after the move I get a message DUPLEX UNIT NOT SET when I try and do 1-2 or 2-2 copies. Anyone have any ideas?
Thanks
Tom
When you open the whole duplex unit you will see a very small metal tab with a screw, on the top right side on the machine. This activates the switch on the duplex unit.
Or with the duplex unit open you will se a small rectangle hole inside a switch, put a piece of paper or something to activate it, might got stuck.
This problem is very common on this machines.
There is a metal tab on the duplex unit that could be bent blocking the sensor. Once it is straightened out it should work.
Bubba
I cannot locate a metal tab.....
I am talking about a 2035G unit.
The feeder works to do 1-1 copies.
it also will do 2 up and 4 up on same page
but not back to back
HELP
