N5030,work for 2 weeks and then stop working. has win 7, brought from Geek.com last month
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
SOURCE: mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
SOURCE: mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
SOURCE: My Acer Netbook 10.1 touch pad stopped working. I
hi
you might have accidentally pressed teh touchpad togle button try the fn+f7 key or some other function key with the rectangle and a hand figure on it
hope it might have helped
cheers
SOURCE: The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
hi. have you check mouse lock button on your mouse pad. if it in lock position your mouse scroll cannot move but if it in unlock position that most posibility your system got something wrong with mouse setting.
