You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Good Luck
You can certainly turn off the wireless signal. This is located under Wireless Setup -> Radio Setup on the router's administrative page. If you are hard wired to the router, do the following:
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
