SOURCE: car stereo wiring diagram
Hi again,
I was made to understand that your particular model is exclusively available only to the European market and not here in my country.
The only info I can provide is links to the Mitsubishi-Forums.com:
Alternately, pls try Oakley Mitsubishi.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: i need to know the wiring diagram for a sony CDX-L550X
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C217600&sliceId=1&sonymodel=CDXL550X&sonyregion=US&sonytemplate=1&product=SG_CDXL550X_5_12244&fes=true
this is the wire diagram for that radio .
http://www.docs.sony.com/release/CDXL550X.PDF
here is the owners manual.
J5
SOURCE: I need a wiring diagram for a Sony CDX-GT320 car
Sony has manuals on their webiste.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT320&LOC=3
SOURCE: I need the Wiring Diagram for a Sony CDX5070 Car
Should have standard aftermarket wire colors ( yellow-12v, red-switched, black-ground, blue w/ white-amp turn on, blue-power ant., White-LF speaker, Gray-RFspeaker, Green-LR speaker, Purple-RR speaker, the ones with the black stripes are negitive)
SOURCE: need the wiring diagram for a sony car radio
GRAY PAIR:SPEAKER
GREEN PAIR:SPEAKER
WHITE PAIR:SPEAKER
VIOLET PAIR:SPEAKER
BLACK:GROUND
RED:IGNITION CONTROL
YELLOW:12 VOLTS MAIN
LIGHT BLUE AND STRIPED BLUE:REMOTE OUT MAX .5 AMPS
I know which wire it is, now The problem is I don't know how to hook the illumination wire to the wiring harness on the stereo.
