Computer, Chip, Cruise Control for Kia Optima Logo
kelly Burt Posted on May 01, 2012
2004 kia optima cruise contol not working green on light turns on but cruise does not work checked brake lights not the problem
Cruise control not working green light comes on, but the cruise will not engage checked brake lights that was not problem
Anonymous
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 55 Answers
  • Posted on May 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Cheetah:
Answers
55
Questions
Helped
12373
Points
74
Most cruse controls have problems in the steering column?
2009 SEDONA, CRUISE CONTROL IN-OP. ESC LIGHT ON/OFF. CODES STATED BRAKE LIGHT SWICH. CORRECTED ESC LIGHT CRUISE STILL NOT WORKING. ALL FUSES GOOD. REPALCED TPS, TEST CRUISE SWITCH, GOOD. TESTED CURRENT...
There are two switches on the brake pedal, one for brake light, and one that kicks out the cruise when you hit the brake. That switch is closed when depressed (ie; brake pedal is up) and opens when pedal is pushed away from the switch, (unlike the brake light switch which closes when the pedal is pushed). This means it must be positioned and adjusted correctly for cruise to work.
2008 kia optima my cruise quit working and check engine light came on
see what the code is most auto parts stores will scan it for free in hopes to sell parts some car the cruise will shut off when the check engine light is on
I have a 2004 Kia Optima and it left me stranded on the road, came to a complete stop, I turned off the ignition then turn the key again and it started up fine. It had happen a couple of weeks ago and...
You need to have the codes checked. when you cycled the key , you were resetting the ECM. This didn't fix the problem. Get the codes and let me know. We can go from there. There are to many things to list that can shut down engines. And you don't need to buy expensive parts that you don't need.
Randy
My 2006 Kia Optima brake lights stay on constantly only when the car is running. When the car is shut off, they will function correctly. All fuses ok. Not sure where else to check.
Does your cruise control work? If not it is the brake light switch. It will be a small mechanical switch that will be activated when pushing down on the brake pedal. May need a new switch or just adjusting.
Brake light not working on Kia 2005 Optima tali lights work, bulbs replaced brake light switch replaced but still no brake lights
Check the space gap between the brake lever to the brake switch.
Also check the connector to the brake switch.
You have to look under the dash carefully.
These is not too much room under there.
Just ran you hand along the brake paddle.
Press the brake switch by hand and see is brake light go on.
Check all connectors for corrosion.
6helpful
2answers
2004 kia optima,break lights stay on,taillights will not come on,bulbs are ok
It sounds as if your brake light switch is bad, or, your brake pedal return spring isn't pulling the pedal back towards the seat.
First, just pull up on the brake pedal, opposite direction of when you are applying them & see if the lights go off. If yes, you'll need a new return spring. If not, then usually the switch mounted up above the pedal is defective & needs to be replaced.
I believe once that is corrected, the lights should work properly if your parking lights are working, as they both use the same circuit. If not, you'll have to do some testing of those wires & backtrack to the light switch.
The Brake light switch also can have the cruise control switch & other controls associated with it but not always, depending on the specific Model & Year & other options so testing it could require a wiring diagram, I've included a link that will give you the wiring colors for the brake light switch itself. Testing the wiring is the only way to determine any other condition that would be causing that to happen.
Here's the link for the wiring:
http://www.commandocaralarms.com/wiring/2003-2005/Kia/Optima/893.html
It shows the brake switch wires as GREEN.
Good Luck.
1helpful
3answers
2004 Kia Optima EX...Brake lights suddenly don't work. Fuses are all ok...bulbs are all ok...and the switch box that's under the steering wheel is also in working order. Where else can I check for the...
You can check to make sure that the taillights have a good ground. If at all possible try using a test light or multimeter at the light. Have someone step on the brake and see if you have positive voltage to the light. If you do then it could be a faulty ground. If you don't move closer to the brake switch or even test the brake switch.
2004 KIA Optima
Check the fuses for these items they could be blown.
2helpful
Air bag
If the air bag light is blinking count the blinks for the code. Example.. If the air bag light flashes once and then a short pause and then two blinks you would have a code 12. and so on. If it just stays on you will need to take it into a repair shop and get it checked. My best guess without looking at it would be that the clockspring is not working properly. Most of the time when the clockspring goes out other things stop working like the horn or cruise control or something that is on the steering wheel. Hope this helps.
Cruise control
make sure to check all the fuses and specially tmake sure your brakes lights works because they comuncate w/ cruise
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
