My maytag dryer sde4606ayw is making a loud screaming noise when drying. Sounds like metal on metal. It continues for a second after the drum has stopped turning and there is a faint burning smell inside the drum. I clean out the ducts and vents regularly. Could this be a fan motor or a drum guide?
It sounds like the bearings are going out or tensioner is loose allowing belt to slip probably the bearings
It could be the band slipping, depending on how handy you are, you can take out the back cover and check it out while it runs. I am assuming this is an electric dryer, so taking the back cover is not so difficult, just need to figure out what type of screws it has, find the corresponding tool and take it out (make sure power is unplugged while you do this) plug it back it and let it run, you can find where the noise is coming from. If you cannot figure it out, put everything back on and then it is best to call a technician.
SOURCE: older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
SOURCE: Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
SOURCE: Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
SOURCE: Maytag Neptune Gas Dryer will
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
