What can I do to fix and identify this issue???
SOURCE: the acer aspire laptop does not boot up
This is one or two things.
HARD DRIVE PROBLEM
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the software.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it as if you were doing a setup and then when the second repair comes up..... hit repair. This should repair any problem with the operating system. If you want to try the simple way... use the first repair that comes up. When the screen comes up with a blinking curser hit the number 1 then Enter........ When it ask you for a password hit enter. There should not be a password unless someone has put one in it. If there is a password it should be your master password.
Then type fixmbr and hit enter. This will fix your master boot record. If that does not work use the second repair. Sounds complicated but it is not.
SOURCE: Acer eRecovery Problem
When you Formated the Dirve You Deleted The Hidden Recovery Partition
SOURCE: My Acer laptop just crashes randomly..i used to
Acer usually has a hidden partition which allows you to reinstall the OS back to factory setting.When you boot hold down the ALT + F10 button and it should boot into the recovery disk
SOURCE: My Acer Aspire 5570Z laptop's power button issue
Underneath the power button that you see is a small board with a tiny tactile button. These tactile buttons because they get used alot tend to go bad. They will get worn out and then eventually won't work.
Best thing to do is to go to this page courtesy of Acer:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
There is a phone number there and they should be able to tell you if your laptop is under warranty. If its not, ask them the name of the board underneath the power button and its part number and you can search for it yourself on the internet to get the best price
