Question about Honda Pressure Washer PSI 3000
Cant get soap to come out of resevior
The soap is not feeding through the resevior tube
    Brigadier General:
  • 6,468 Answers
It only will pull soap with the large hole tip or no tip very low pressure
Posted on May 03, 2012
SOURCE:
Nilfisk 150.2 willnot dispence soap when jetting
i have some bad news for you. when using soap not recommended by the manufacture, and you use the machine and use another type of soap or cleaner after you do not run water through the machine to clean the tube and sprayer out of soap the soap drys up and kluges the tubes and the sprayer, and you have to take it to be repaired or buy a new machine. i can test to that the hard way i loaned mine out and it was returned dirty and soap was dried up inside the tube and jets, look at the tube if you see dried up bubbles than the machine needs to be repair and service, service center , sew and vac one place vacuum dealer
Feb 28, 2015 | Nilfisk Vacuums
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Oct 04, 2014 | Garden
Windshield washer not working. No water spray
I'm assuming you can hear the pump motor run, the resevior has washer fluid in it, but there's no spray... correct? Then the problem is most likely a clogged pump inlet screen. You will need to access this pump/resevior from the right hand side wheel well (liner moved out of the way) and disconnect the wiring connector at the pump & the rubber hose at the pump housing. This particular pump is 'snapped' in place with plastic holders as part of the resevior housing and a rubber grommet where the inlet tube of the pump is inside the housing. Once you remove the pump, the inlet screen can be removed & cleaned. You'll also want to flush out the reseviore to clean it. Refill with fresh water & W.W. solvent after you reinstall the pump after cleaning the screen. Reconnect the hose and wiring connector to the pump. before refilling.
Sep 05, 2011 | 2006 Hyundai Sonata
How do I disconnect the water line in the bottom of the door in hotpoint model csx24gr
Hi Cheryl,
to do that open the freezer door,remove kick(toe)plate, on the left side under the hinge you will see a plastic union coupling the tube from the resevior to the tube inside of the door unscrew that union and pull the tubing apart. BE PREPARED for some water in the tubing to come out onto the floor and possibly all the water in the resevior may also come out ontothe floor so have a few towels ready
Jul 22, 2011 | Refrigerators
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My k'archer electric pressure cleaner doesn't draw the detergent when flipping to mix, what am i doing wrong?
intake nozzel might be pluged at pump pull tube and clean with paper clip you cant **** soap in pressure mode hole in tubing
Jan 18, 2011 | Karcher Garden
I have a Sears Craftsman Pressure Washer Model No. 580.752010 Soap will not draw from the throut the plastic tube and mix with the sprayed water. Yes I am using the proper nosel and the tube in not...
A brief reminder of how the detergent is mixed may shed some light. There is a vortex with a small feed pipe. The vortex is fed with the water flow and causes a small vacuum in the feed pipe within the Y piece vortex sucking up a measured amount of detergent.
If there is a blockage in the vortex, it will not work.
Check the small detergent feed pipe is clear through the vortex.
Oct 07, 2017 | Craftsman Garden
My KitchenAid washer will agitate, but the upper agitator assembly is not turning and I hear what sounds like marbles moving/slipping. Can I take that top piece off to look at it?
Based on your description, the problem is likely the self-rising tube that comes from the base (bottom) water feed tube. It may not be rising to engage the top assembly....
If it fails to rise all the way, the water will just spray into and on it and cause it to wobble versus rotate.
Pull up on the bottom feed tube - just to confirm that it will move freely...... (food, soap scum and age can prevent it from moving freely.) Clean and retry the washer.....
Nov 07, 2009 | KitchenAid KAWS700L Top Load Washer
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Please rate my solution.
Thankyou.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Cooling system
there should be. its likely a "closed" system, meaning you fill coolant through your resivior tank. look for a plastic "bottle" or "container" next to your radiator, or alond the left side of the engine bay as you face your engine. you should find a cap that says something like "do not open hot- under pressure" on the resivior tank you should see level marks molded into the tank/container. these indicate coolant level at cold and hot. also look for a tube coming out of the tank leading into the radiator. this tube feeds coolant back into your radiator. hope this helps
Jun 18, 2008 | 1991 Chrysler New Yorker
Honda Pressure Washer PSI 3000 Logo
139 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
