When I recieve an incoming call or make one, randomly the ear speaker stops working, I can switch to the speaker phone, so all can hear and this is the only way I can listen. On the next call it will work fine. It does this for a while and then no speaker works. I have had this happen to my 1st Nokia E5 and now it's begining with the new E5, after about a month.
SOURCE: Nokia 6020 Speaker Problem
the mi might be busted..have it replaced or maybe the mic contacts are dirty so try cleaning them off..
SOURCE: Nokia E65 microphone doesn't work
hi thanks for using fixya!!
Did you accidentally dropped the Nokia E65? Well, on this error, you shoudl bring your unit to a service center to further check the hardware error such as the microphone. However, be sure that whenever you make calls you have the network signal high so that you can have quality voice calls.
If you need further assistance, let me know
SOURCE: nokia 6500i
There are a couple of causes:- 1, Faulty Earpiece speaker, change the earpiece... 2, Faulty Ribbon/Flex, it connects the phones main PCB to the screen, the top keypad the front camera and the earpiece, a kink or tear in this can cause any of those to malfunction. Change the ribbon/flex 3, If its only happening when a certain person calls you, the problem could be at their end and they're microphone might be faulty on their handset... 4, Less common but there are IC's that control the sound on the 6500 these could be faulty or have dry solder, these can be either reflowed or replaced.
SOURCE: nokia 6085 speaker problem
It is the microphone that needs to be replaced. Usually it can be replaced no problem, I have done so on the Nokia 6085 myself. But yes, the reason the bluetooth works is because it has its own mic and the mic for the handset has gone bad.
SOURCE: incoming caller id is not working on my new nokia
Did you try to restore factory settings ? If not , then do it . If yes , then update your firmware with Nokia Pc Suite !
that should solve the problem .
Here i'll explain you , how to restore factory settings :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, *
Star key, no. 3 key on keypad and then press the power on/off to swtich on the
phone.
Remember, do not let go the 3 press and hold keys until you see a
formatting word screen show!
2. After a few minutes when the Full
phone formatting completed, your phone will back to original system and factory
settting.
rate please !
best regards .
P.s : You'll lose every infos on your device after restoring , so back everything up before doing that !
